Читаем тему "Internet Indycar League" |
madlopt
Сообщений: 957 Расположение: Планета ШЕЛЕЗЯКА
2 ALL
Вот правила прислали. Т.к. все желающие учавствовать с инглишом немного дружат, мИне лень переводить
Racing Teams
A team can be made up of up to four drivers, all with same engine/chassis combination. Not that there will be a team championship (it is just one race), but to form a team is a good way to share experiences or compare times before the end of the race.
BEFORE THE RACE
Note: Be sure you have all the patches released for the sim used (DOS ICR2, Windy ICR2 or CART Racing).
You can use any number and paint or import your car, and change any personal info you want. You cannot change the skill settings on your car or any of the opponents. All track files and simulator files must be the ones issued here. The carset and driver list cannot be changed except for your car. You may use any paintwork, sound, cockpit or any other utility which does not affect the performance of your or the AI cars. DOS users also may use the Editstg utility, as it allows them to fine tune their setup as well as in the Mac or Windows version.
Set up your ICR2 according to the followings:
-Track used: IMS2K4 (http://forum.m4driving.sm/index.php?showtopic=44126). Note that this track has lower tyre heat values, so you can use soft tyres on all four wheels for qualifying, while for the race most likely you should change your RF to medium. It also has classic Indy-style qualifying (average of 4 laps).
-Use the attached IMS2K4.txt file instead of the original one.
-Carset: Brent Blackburns excellent Indy04_t (http://forum.m4driving.sm/index.php?showtopic=44209), or if you have a low frame rate you may use the MR2003-4 carset used by Macracing league. It uses the origianl carshape, and I will post here a version of it with the same performance values than the Indy04_t carset.
-Race distance: 80 laps (100%)
-damage set to ARCADE
-Random breakdowns and yellow flags OFF
-pace lap ON
-Opponent strength: you have the right to choose it how you like it. However, be careful not to set it too fast as you risk being overlapped, and also not set it too slow as then you have to overlap a lot, which most likely slows you down. As a starting point I suggest 98%. Please keep the same OS for qualifying and race, because not every version allows to change it between the 2 sessions.
-Weather: constant, 66°F/NE 6mph (as on Pole Day), or you may set it to random, as the track txt automatically set it to that weather (it was tested just on the DOS version, but I hope it works on every other version also)
-Number of opponents: 28
RUNNING THE RACE
You should run your race in Single Race mode. When you qualify, save the necessary screenshots and the replay of it. Then save your race, and when you are ready, run the race and when the race is over, make sure to save your results, screen shots of the end of the race, and the replay of your race. The necessary screenshots depend on which version of the game you are using, and are described in details in the next section. You should send in your qualifying and race results to be compared with everyone else's. If you are a member of any league, send your results according to the rules of your league to the address specified by your director (for verification of the validity of your results), and also send text results to me (kakukri@freemail.hu). For the form of the text results see the next section, where I also describe how to send your results if you are not a member of any league. The deadline for both qualifying and race results is 6/6 11:59 p.m. of your local time.
Please run your race once and only once. You cannot re-run your race, and you cannot restart a race unless the AI did something stupid on the first lap and took you out, or your computer hangs up or the computer cars stop at a crash during the race. You also cannot "Save and Restart" a race that has started. Sometimes the computer gliches and puts lapped cars ahead of you in the standings. You have the option of restarting. However, you have the right to run qualifying as many times as you like it. The idea behind this is that qualifying is about how fast you are, while race is about how consistent and fast you are.
The finishing order will be based on the following:
1) Laps Completed
2) Race time
Note: You don't need to win your local race. The time is made from the winner's race time plus the margin shown in the F2 screenshot from the finish line.
SENDING YOUR RESULTS:
Deadline for both qualifying and race results: 6/6 11:59 p.m. of your local time.
Example of the text results (send it to kakukri@freemail.hu):
Driver (number): John Smith(23)
Team: JS Racing
Chassis/Engine/Tyre: Dallara/Chevrolet/Firestone
League: Macracing, IIL, IIRS or M4Driving
OS%: 99%
Qualify: 225.395 mph
Laps completed: 80
Race time: 54:51.5
Avg Speed: 221.350 mph
DNF: None
Those data will be compared with the other sended, zipped results (screenshots, stn files, etc.) and if there are differences between them, the driver will be disqualified.
What to save for non-league drivers?
For every version, please do not forget to save your qualifying and race replays. From the race replay it is enough to cut the last part of it starting with the beginning of your last full lap. That means if you finished the race, you have to start just before the white flag, and your replay should contain your last and cooling down laps. If you were unable to finish your race, your replay should contain your last full lap and your last fraction lap (on which you crashed out). Please keep these replays for a possible post race inspection until the official results will be posted.
Листинг конфига для Индианаполиса.
TNAME Indianapolis
SNAME Indianapolis
PIT 270867 67345668 25958251 754668 3871751 468967 30057751 18 72272000 72272001 5290000
PIT2 270867 67345668 25958251 72382668 413751 468967 30057751 15 72272000 72272001 5290000
SPDWY 1 33 35
LENGT 2500
LAPS 80
FNAME ICR2 Indianapolis 200 Open
CITYN Speedway, IN
COUNT USA
PACEA 3 78736001 140000 28000 -84000 0
QUAL 1 4
BLIMP 298800 1416000
GFLAG 68850000
TTYPE 3
CARS 29 29
TEMP 660 0
TEMP2 660 0
WIND 536870912 0 60 0 180
WIND2 536870912 0 60 0 180
SUN 270 80
RAIN 00 00
BLAP 38200
RELS 105
THEAT 8500 5500 2750 15000 12000 9000 7000 12000
TCFF 61535 59535 57535 57535 30800 29989 28989 39000
TCFR 65535 63535 61535 61535 34800 33989 32989 43000
TIRES 85535 3500 126000000 85535 8500 126000000 0
TIRE2 85535 3500 126000000 85535 8500 126000000 0
SCTNS 8 5 3
Блин заархивировали какой-то мутью карсет, надо ещё какие-то проги доставать, чтоб слепить два тома архива.
Quote: Orginally posted by Denton
Нее Пуков нам не надо
Гыгыгыгы
____________________________ Devastation everywhere!
21-05-04 13:06:01 |
Leonardo
Сообщений: 101 Расположение: Краматорск, Донецкая обла
Т.К. МОЮ ТЕМУ НУЖНЫЕ МНЕ ЛЮДИ ЯВНО НЕ ЧИТАЮТ ДУБЛИРУЮ СЮДА!!!
1.Дентон! ПРЕДЛАГАЮ ТЕ РАССКРАСКУ ШУРИКУСА! ОН ВСЁ РАВНО УШЁЛ и №6? Ты как?
2.Леонардо - 32(1)
ТИЛЛ13 - 13
Бейджинг - 25
мадлопт - 17
Алекс - 16
Glo-Finn-Dale - 38
2Хардер - 17-ый мадлопт!
3. Фонарик, Ал, Глор-Финн-Чип намалюйте ХОТЬ ШО-НИБУДЬ!
И ещё! Кому этот карсет делать, а кому нет!
Просто, т.к. он делаеться каждому индивидуально, не хочеться лишней работой заниматься. И ещё. Ал - ИНФУ О СЕ МИНИМАЛЬНУЮ ДАЙ!
ВСЁ!!!!
ЖДУ!!!!!!!!!!!!!!!!! ОЧЕНЬ ЖДУ!!!!!!!!!!!!!!!!!!!
____________________________ С УВАЖЕНИЕМ...
21-05-04 14:22:57 |
madlopt
21-05-04 16:14:51 |
Fonarick
Сообщений: 52 Расположение: Питер
3. Фонарик,
привет, из меня малеватель как из свиньи балерина
Могу кинуть данные которые я хочувидеть на болиде, и гамму - может кто-нить нарисует?
Я гнеленивый просто софсем неуме. этого.
Ал, в принципе обещал попробовать... но пока молчит.
Чипа не будет. Уволили мальчика из нашейконторы...
Я хочу
22-05-04 12:42:33 |
Harder
Сообщений: 38 Расположение:
2.Леонардо - 32(1)
ТИЛЛ13 - 13
Бейджинг - 25
мадлопт - 17
Алекс - 16
Glo-Finn-Dale - 38
ВСЁ!!!!
Ну нехай буде 7.
____________________________ Do You Wanna Get Rocked ?
22-05-04 13:10:56 |
madlopt
Тем кто поедет в совместной Инди500.
Как вы поняли там нуно окромя результа ещё текст посылать с результом. Так вот форма его чуть изменена.
Nationality: USA
Team: JS Racing
Game version: DOS/Windy/Mac
Controller: wheel/joystick/gamepad/keyboard
OS%: 99%
Laps completed: 80
Race time: 54:51.5
DNF: None
Команда у нас всех будет одна IIL Stars. Всёравно более 4х человек не поедет. Шасси, двигатель и шины нужно использовать одинаковые. Какие бум использовать?
22-05-04 21:38:07 |
madlopt
24-05-04 14:05:00 |
madlopt
Ну чё, друзья-товариСЧи...Заводите свои блин моторы блин, и вперёд блин в Техас! Четвёртый чемпионат IIL начался! УРЯЯЯ!
25-05-04 10:45:34 |
Leonardo
"Четвёртый чемпионат IIL начался!"
С чем я всех и поздравляю!
"Ну нехай буде 7"
Опоздал...
В этом чемпе будешь 18. В след 7 сделаю.
ТЕбе карсет делать?
ЗЫ: Просьба ответить до конца недели!
По поводу Инди500 - карсет у них отстойный.
Врубитесь в стену - поорёте!
25-05-04 15:35:17 |
madlopt
2 Лео
А может они специально так сделали....
2 АЛЛ
Я тут нашёл один баг, если мона так сказать. Количество используемых трасс в игре ограничего, точно количества не подсчитал, но это не трудно, хехе, так вот я ломал голову как-то почему у меня Зандвоорт и Монца не пашут, удалил один трек и поставил Зандвоорт...всё заработало. Трасс у меня более 20ти. А ограничения на кол-во карсетов помоему нет, у меня штук 30 стоит.
25-05-04 16:07:51 |
madlopt
26-05 :: В нашем чемпионате пополнение! Заявку на участие подала команда RRT из России. За неё будут выступать гонщики AP-Racing и Riskoff. AP-Racing будет использовать шасси Рейнард, двигатель Хонда и шины Гудьир, на чём будет ездить Riskoff пока не сообщается.
УРЯ!!!!!!!!
26-05-04 15:34:43 |
Leonardo
УРЯ!!!!!!!!
А в перерыве между чемпами заявиться нельзя было???
У меня как раз в карсете два места оставалось - я туда Баумгартнера и Верстаппена вписал, а так бы вы были.
Ну, слава Богу, дефолтовый я ещё не клепал... Вот теперь думаю, Вас туда совать или нет.... Наверное не буду... Терпите до след. чемпа
27-05-04 12:38:16 |
Leonardo
УРЯ!!!!!!!!
27-05-04 12:38:17 |
madlopt
Это ты меня спрашиваешь?
Ну это уж помоему совсем...причем тут Ферстаппен с Баумгартнером к IIL или к Champ Car'ам????
Ты б сначала спросил хотят ли они на нём ездить, хехе.
27-05-04 14:11:00 |
Leonardo
"Ты б сначала спросил хотят ли они на нём ездить, хехе."
Не для них карсет, а в тот, который уже есть их всобачить!
28-05-04 11:17:14 |
Leonardo
"Ну это уж помоему совсем...причем тут Ферстаппен с Баумгартнером к IIL или к Champ Car'ам????"
Первые два гонщика которе на ум пришли...
28-05-04 11:23:45 |
madlopt
Всем кто поедет в совместной Инди!
Я узнал, можно использовать старый Индианаполис, что у нас на сайте висит, 1.5МБ. Только ТХТ файл обязательно из нового, выше я эту тиэкстишку постил.
28-05-04 15:17:03 |
Riskoff
Сообщений: 26 Расположение: Мытищи, РФ
Вопросы новичка
Господа, всем привет. Завербовали
У меня вопрос по ночному Техасу. Скажите пожалуйста: это трасса кривая, или мои настройки? На второй части поворотов регулярно происходит одно и тоже: срыв задней оси и занос... Самое смешное то, что из 180 mph я ловлю машину и продолжаю движение... Напрягает...
АПДЕЙТ: Кстати, я так понял, что управление джойстиком не запрещается?
28-05-04 18:09:18 |
madlopt
Это трасса такая, правда от настроек тоже зависит, мне удалось настроиться более-мение нормально, чтоб юзом не несло. Только чуть слышно, как шины пищат.
Не запрещается, т.к. на овалах приемущество у рулей и джойстиков, а на роудкорсах приемущество у клавы, овалов и роудкорсов равное количество
28-05-04 18:26:58 |
Riskoff
Ну слава Богу А то уж я подумал, что совсем ездить разучился...
Ok, будем искать натройки. Квалификационную-то я кое-как оформил, чтобы не сносило. А вот в гонке, с полными баками, проблема...
Значит преимущество всё-таки будет Ибо я вообще-то всю жизнь на клавиатуре гоняюсь, а джойстик только для "леталок" использовал. Но буквально вчера попробывал NFS SE на джойстике прокатить. Понравилось: теперь твёрдо решил и овалы в ICR2 на джойстике катать
28-05-04 19:48:20 |
Leonardo
Приветствую!
У меня не сносит, хотя от настроек зависит...
По поводу джойстика уже ответили. Я всё езжу на клаве - по-моему неплохо получаеться и на овалах(намного лучше чем на РК )
28-05-04 22:05:26 |
Riskoff
Leonardo
Блин... Запарился. Конечно, в последний раз я катался в эту игру три года назад. И ещё тогда настраивал машину не лучшим образом... Но простите, я в первый раз сталкиваюсь с ситуацией, когда нацеливаю настройку не на то, чтобы ехать быстро, а на то, чтобы на трассе удержаться... Неприятно
Сейчас проводил эмитацию гонки. Один раз попал в аварию по своей глупости и чинил антикрыло, а затем в программе произошёл баг - машина улетела с трассы на ровном месте... Пришлось снова чиниться... Но речь не об этом. По рассчётам получается, что лидер гонки должен обогнать меня на 3 круга за 80 кругов гонки. Вот они: последствия настроек машины на стабильное управление...
Не-е-е... Сейчас проехал 73 круга Техаса и совсем не устал. А ехать овалы на клавиатуре, по опыту знаю - это самое жестокое испытание. Пальцы устают, сам потеешь, а после гонки так утомляешься, что не соображаешь не фига. Помнится, как мы с друзями 100 лет назад устроили междусобойчик. Правила были жестокими: 60% дистанции и реалистичные повреждения. После гонок в Хоумстеде и Индианаполисе я понял, что больше никогда не сяду за ICR2. Вот вам и "прелести" клавиатуры.
А, вот ещё два вопроса родилось.
1) А зачем мы едем квалификацию?
2) Можно ли стартовать в гонке с последнего места, игнорируя результат квалификации? С последнего места, за пейс-каром, стартовать мне намного удобнее.
28-05-04 22:40:52 |
madlopt
Гыгы
Да, в гонке и у меня проблемы есть, ну ничё.
Я как-то в первом чемпе бьился с Роуд Америкой, и так и сяк...уже бросил руль и на клаву перешёл, дык результаты были ещё хуже. Когда к рулю привык, то вот так сразу на клаву сесть и поехать-это непросто.
Бывает, у меня например
А продробнее...?
Не-е-е... Сейчас проехал 73 круга Техаса и совсем не устал. А ехать овалы на клавиатуре, по опыту знаю - это самое жестокое испытание. .
Дааа. Это точно.
А шоб було Квала в принципе влияет только на локальную гонку, но за поул даётся очко в чемпе, так поэтому квалы учитываются.
А это так необходимо? Если уж так сильно нужно, то можно с последнего места.
29-05-04 09:20:40 |
Leonardo
"Пальцы устают, сам потеешь, а после гонки так утомляешься, что не соображаешь не фига. "
Да! Сначала было чуть-чуть, но потом, когда привыкаешь, всё нормально становиться
29-05-04 10:47:38 |
Riskoff
madlopt
> А продробнее...?
Подробнее только реплей. Скачать можно по этому адресу: http://kalschikov.front.ru/temp/scrash.zip
Опыта нет - отсюда и проблемы. За пейс-каром остывают шины и из середины/головы пелотона, на статре, я устраиваю аварии. Напротив, с последнего места я делаю хороший старт, никого не цепляю и к первому повороту овала оказываюсь в том месте, откуда должен был стартовать
29-05-04 11:25:34 |
TILL13
Сообщений: 41 Расположение: Якутск, Россия
у меня тоже жопу срывает....не знаю хватит ли у меня терпения проехать гонку.........молитесь чтоб хватило
29-05-04 18:33:45 |
madlopt
2 Riskoff
Да, действительно баг, я такое впервые вижу, покадрово попытался посмотреть, насколько это возможно. Машина вдруг оказалась вне трассы, причём далеко , а потом опять вернулась на то же место, но видать часть проги, которая отвечает за просчёты аварий и т.п. увидела координаты машины вне трассы и получилось будто бы машина куда-то врезалась.
Было что-то подобное у меня в Лонг Бич, я въехал в тачку бота, крутился, не мог выехать и вдруг пролетел через забор, вернуться назад нельзя, но вне трассы ездит можно
PS
Кстати я не представляю, как Лео ездит на клаве на овалах, причём быстро.
PSPS
Симтек скоро должен пополнить наши ряды
____________________________ Devastation everywhere! Last edited by: madlopt on 29-05-04 19:01:13 |
29-05-04 19:00:24 |
Leonardo
"Кстати я не представляю, как Лео ездит на клаве на овалах, причём быстро."
Ты мне льстишь...
"Симтек скоро должен пополнить наши ряды"
Эт радует...
Кстати, Инстанция, ты карсет видела???
Взяла у Алекса посмотреть???
Надеюсь, что да.
Можно будет при возвращении симтека одну строчечку там подправить(надеюсь, что да) и ещё!!!ЕСЛИ КОГО-ТО НЕ УСТРАИВАЕТ, ЧТО ОН ОТОБРАЖАЕТЬСЯ КАК "ИМЯ ФАМИЛИЯ", А НЕ НАПРИМЕР "Михаэль Шумахер"(ничего личного), ТО ПУСТЬ СКАЖЕТ МНЕ СВОЁ ИМЯ!!!!(и я думаю наша добрая федерация разрешит подправить ещё несколько строчичек
ЗЫ:Хорошо хоть дефолт на сайте ещё не лежит
____________________________ С УВАЖЕНИЕМ... Last edited by: Leonardo on 01-06-04 17:12:44 |
30-05-04 13:09:28 |
Riskoff
Leonardo
Надеюсь, что да.
До боли знакомые хлопоты. Помнится, когда я организовывал чемпионаты по Grand Prix 2, карсеты приходилось переделывать чуть ли не через каждую гонку... BTW, в карсеты я зашивал имена участников чемпионата, а не гонщиков Формулы-1. IMHO, так интереснее: гоняться с соперниками, с которыми боришся в чемпионате, постоянно видеть их имена, раскраски машин
30-05-04 14:08:20 |
Леонид
Сообщений: 1 Расположение: web
Привет всем! Я тут интересовался Вашим чемпионатом. Рулез. молодца. Немного освоюсь и присоединюсь к вам. Единственное - у меня в w2к че-то игра криво пошла. Надо разобраться...
____________________________ Per asoera ad astra!
30-05-04 19:11:59 |
Riskoff
У меня в Win2k игра вообще не пошла. Так что ничего странного в этом нет
31-05-04 07:38:07 |
madlopt
Велкам!!! С VDMSoundom запускал??? Если без, то понятно почему проблемы.
2 Рискофф
Меня не прикалывает обгонять к примеру тебя в локальной гонке, а потом узнать, что ты первее в общей Да и опять же проблемы с карсетом...гемор это.
31-05-04 11:12:22 |
Riskoff
Я запускал. Разницы не увидел
Прекрасно понимаю тебя. Тем более, насколько я успел ознакомиться с софтом для ICR2, полноценной и удобной утилиты для карсетов до сих пор не придумано.
В конечном итоге, я лишь высказал своё личное мнение, которое никого не должно к чему-то обязывать
Кстати, мои результаты Техаса до тебя дошли? Или к кому они там идут через results@champcar.com.ua?
31-05-04 11:20:44 |
TILL13
бля ну эти боты реактивные просто.......ну в принципе даже так интересней ехать было......ато когда их обгоняешь на круг они тупят уроды....а так чисто ехал.......обидно только что на пите время потерял........мимо проехал...бля........а переезжать обламало итак за*****бал уже этот техас.......
31-05-04 19:34:40 |
TILL13
результ вроде ушёл на мыло...через сайт загрузить не получалось..........
31-05-04 19:43:23 |
